720D tranny stuck in 3rd
onslow
05-01-2005 19:12:18
My neighbor has a 720D which only gets started and driven about every 3 months (If I go over and start it). This time, I decided to work it a little, so instead of just diving around the neighborhood for 30 minutes as usual, I hooked up a sub-soiler and busted up a pasture. Everything was going well, in 3rd gear but later when trying to change gears the shifter would come out of 3rd and go into 5th and 6th positions but does not seem to actually change gears (runs same speed in 3rd, 5th and 6th. It will not however, go into the 1st, 2nd, 4th and reverse positions or gears. Any suggestions?
Mike M
05-02-2005 11:42:01
 Re: 720D tranny stuck in 3rd in reply to onslow, 05-01-2005 19:12:18
Your shift forks,levers,and trans. bearings are old and worn. This happens alot on these old tractors.You need to be real careful when shifting the gears on these especially when you go from one side of the quardrant to the other and make sure that you feel the lever move the fork all the way. You are going to have to lift the top cover up so you can realign the forks and put the lever back in it's place.
