For Duane Larson- D manifold
Bob-Wyo
05-01-2005 18:34:59
You posted,-A friend has a late styled D with a manifold which has separate intake and exhaust castings. The exhaust manifold has a casting number LOD 1981, and there is no casting info on the intake casting. He says it is not the dual exhaust manifold - I have not seen it.
Hi Duane, I finally got to look at my LP manifold and came up with LGD1981, (the G maybe a O) so his is a LP manifold. Now we have another answer on the compression rings/donuts/inserts, via the May/June 2 cly Mag page 18, some, if not all were made by the Hollingsworth-Stempel Co of OLLIE,Iowa. The inserts and cold manifold were called the Hollingsworth HiCompression System, a low cost alternitive to the power block for building more compression and burning Gas and available for A-B-G-D, STANDARD OR .45 OVERSIZE. Wish they could of printed some part #'s, as I have 2 other supposely cold manifolds both different, but both are pulling the intake down the middle of the exhaust and then with a S shaped casting bolted on to the side. The picture is not too clear, but does not seem as heavy as the 2 sets I have in D's and each set is different in design also. Both sets really shroud the exhaust valves on the side's.
Now Deere made a cold manifold,D3412R, and gas pistons, also high altitude pistons.(sure would like to know the dif here, thought they both just upped compression)
Still like my Rosewood dual exhaust setup best. Hope somday we can meet at the MACHINE SHED Duane, I'm buying, man I miss that place, guess better make another trip to ILL again soon. Hope this will help a little,
Bob
Glen in TX
05-02-2005 21:59:36
 Re: For Duane Larson- D manifold in reply to Bob-Wyo, 05-01-2005 18:34:59
Bob, Thanks for the LP manifold number. I'll let you know if I run across any like that. I can take a pic of a gasoline D3412R manifold if you want to see one but is it pretty much the same as the others except not as bulky in the inlet area and the carb inlet flange is shaped the same as on the carb instead of round. I'm still wondering what the D2734R export only manifold was for the Ds?
Duane Larson
05-02-2005 20:02:48
Hello Bob,
Thanks Much for the info - I'll pass it along. I wonder if that is a Johnson LP manifold unit? I don't recall seeing any D conversions to LP - did they replace the normal gas tank?
I stopped by a friend's place near Davenport on the way back from LeSueur swap meet, with the intention of eating at the Machine Shed. Well, we got to talking and looking at wheels, and by the time we got there it had closed for the night! So, that meant I had to hang around another day and we made it the second evening. Hot roast beef with potatoes and gravy - yum yum!
Just let me know when you'll be there...
Glen in TX
05-02-2005 22:18:11
 Re: For Duane Larson- D manifold in reply to Duane Larson, 05-02-2005 20:02:48
Duane, Type in LP Conversions in a search and find a post about J&S LP carb conversion. It was March 26. I found it again but couldn't open the pics anymore but that styled D had a large LP tank replacing the gas tank with hole cut in hood and had the conversion with hole drilled above nozzle area on carb and a regulator converter bolted to side of hood. Some other Ds I have seen on LP had converter bolted to the side of radiator. Kinda ugly but I guess it worked?
Duane Larson
05-03-2005 06:45:39
 Re: For Duane Larson- D manifold in reply to Glen in TX, 05-02-2005 22:18:11
Thanks for the info, Glen.
Glen in TX
05-03-2005 10:28:17
 Re: For Duane Larson- D manifold in reply to Duane Larson, 05-03-2005 06:45:39
I found out the one old LP equipment supplier J&S from Dallas was absorbed by IMPCO. IMPCO LP and natural gas equipment has long been popular in this area on stationary engines and others. Here are some links for modern LP equipment. www.impco.ws/ www.acmecarb.com/index.html
www.zenithfuelsystems.com
Glen in TX
05-01-2005 22:00:48
Bob & Duane, I found a ad for the Hollingsworth Hi-Compression System inserts and posted it on Vintage Ads here. I have a set of these for a D. Also found a ad for the Johnson pistons and manifolds used on JDs. The D3412R manifold you talk about was a gasoline one-piece manifold that came on many later Ds or was changed on others later. The Hi-Altitude pistons were just a bit longer for more compression. Have had several Ds with these manifolds and pistons with the DLTX63 gas carbs that ran well.
