4010 tranny problem
jdjerry
05-01-2005 17:47:51
windrowing rocks in low gear at low rpm
heard a bang now tractor wont move in any gears
any ideas is the tractor junk
donmyeil
05-04-2005 07:04:22
 Re: 4010 tranny problem in reply to jdjerry, 05-01-2005 17:47:51
Try steping on one brake at a time with tractor in gear. might have sheared the key of one wheel axel half. DON
Gerald J.
05-02-2005 08:57:48
Something in the drive train, probably transmission output shaft or differential. Though it could be a clutch plate.
4010 didn't have differential lock so you can't check for a broken differential that way.
The lowest gears weren't really made for maximum thrust so many rear end pieces are not up to all the torque the engine can produce in first gear.
Probably need to start the inspection by getting at the differential, then go forward or sideways from there. Repair could get to be expensive.
Gerald J.
