Cam shaft has Knock/720 lp
Ben.So.Tex
05-01-2005 10:20:15
I checked my clearance on the tappets all good, checked for wear also, they are getting good oil, But it sound like it knocking at the cam shaft..How is the cam shaft oiled? (slung oil or oil line).. sounds like only one lob on the cam to be the problem. It has a fairly hard knock.. Ben
buickanddeere
05-02-2005 08:55:33
 Re: Cam shaft has Knock/720 lp in reply to Ben.So.Tex, 05-01-2005 10:20:15
Pull the plugs, dis-engage the hydraulic and pto. Then roll the engine over by hand with the pulley and listen closely.
Ben.So.Tex
05-01-2005 11:02:09
Could it be valve slap? the valve closing back against the head? I have not worked the tractor yet.. Maybe thats what it need to get everthing seated. Ben
Tyler-MO
05-01-2005 23:25:02
 Re: Cam shaft has Knock/720 lp in reply to Ben.So.Tex, 05-01-2005 11:02:09
Ben,
It might be possible for the valve seat insert to have came loose or be somewhat loose in the head. I"ve never heard of this but who knows. I would get out the stethoscope and do some listening at slow idle hopefully you can home right in on the problem. Tyler from Missouri but right now in (germany)
Ken C.
05-01-2005 20:11:59
I had one that the bolts that hold the gear on the cam got loose, made a noise.
