DJM, To adjust valves try this process, Take out spark plugs, *turn over engine with fly wheel in running direction until # 1 cylinder (fly wheel side) is at top dead center on the compression stroke and fly wheel (LH impulse) line is inline with mark on tranny cover. Both valves should be closed on # 1. Another way to check that # 1 is on the compression stroke is to put your thumb over the spark plug hole and feel for air pressure while turning the flywheel. *insert small allen wrench in # 1 spark plug hole and move flywheel until piston feels like it is at TDC * Adjust valves on # 1 piston with a .022 feeler guage when engine is cold and .020 when engine is hot. Loosen lock nut and adjust with adjustment nut until feeler guage fits between valve spring and tappet (rocker Arm)on both intake and exaust valves. *turn engine over 180 degrees and use the allen wrench method to make sure that #2 cylinder is @ TDC and adjust valve cleance as mentioned above. *Once engine gets to normal operating temp. of 160 degrees for about 10 minutes. take of tappet lever cover (valve cover) re-torque head and reset valve clearance @ .020 No Problem, GreatDain
