Deere walking plow
PeterE
04-30-2005 21:45:00
Not exactly tractor related, but I do not know where else to ask.
I just purchased two Deere steel beam walking plows. Each plow has a number on the beam, and another on the moldboard hardware. One plow has a 192 beam, with 7210 on the hardware. The other has a 191 beam, with 7794 on the hardware.
I have seen some lists online, but they do not have beam numbers that low. I think the lists were wheeled plows.
I would appreciate it if anyone had a general estimate of the years. Or if there are any books or other sources I should locate.
Dave NE IA
05-02-2005 17:57:01
 Re: Deere walking plow in reply to PeterE, 04-30-2005 21:45:00
Thanks guys Dave NE IA
RHM
05-01-2005 12:47:59
In the shop I found the plow has a 580 beam which is green, the red is most evident in the stamped depressions for the lettering JOHN DEERE, but is also found outside this lettering, but not in the stamping 580. The back of the moldboard appears to have been green and the right-most hardware attaching the handle to the moldboard is clearly green. The inside of the landslide is clearly green. The straps from the handles to the beam have a patina of rust. Removal of the left one revealed either a thin coat of black paint or the black of black iron. I suspect it is the later, although it may be that the black paint was poor quality or a particularly thin coat. The plow may not have been new in 1929.
I Bleed Green
05-01-2005 05:59:09
July 2000 Green Magazine has this info. Beam no. 191 is model NA6 Beam No. 192 model NA7. NA4, NA6, and NA7 stubble-steel beam walking plows right hand discontinued 1941
PeterE
05-01-2005 08:12:31
 Re: Deere walking plow in reply to I Bleed Green, 05-01-2005 05:59:09
Thank you very much for the information.
Dave NE IA
04-30-2005 22:17:16
I also would like to know the color break down of the JD walking plows as well as the handles. Thanks Dave NE IA
PeterE
05-01-2005 08:16:17
 Re: Deere walking plow in reply to Dave NE IA, 04-30-2005 22:17:16
I had found the following PDF file at Deere's site. It indicates unfinished handles, with a variety of paint schemes on the plow. Green, yellow, red, and black were common.
RHM
05-01-2005 05:51:13
Green beam, red patch on top of beam about 8" long and unfinished handles according to my memory. About 1929 vintage. After church, breakfast with friends and changing clothes, I can worm my way to the back of the shop and get further details.
