AR Question
Ralph(OH)
04-30-2005 12:05:41
My father owns a John Deere AR. I can find plenty information about the R but none about the AR. Can someone help me with what makes the AR diferent?
DAN IN OHIO
05-01-2005 05:48:57
 Re: AR Question in reply to Ralph(OH), 04-30-2005 12:05:41
Ralph, the AR was made until 1953, I have one. The later model (those made in 53) have the factory installed water pump and live hydraulics like the 60. In fact the motor in the later model is just like the 60 except it does not have the duplex carb. Sure wish they had power steering like the 60. See Green Mag. May of 96 for a detailed article on the styled AR.
billde
04-30-2005 12:45:44
Ralph, the AR is smaller lighter less hp and gas instead of diesel. The AR would be sort of a utility version of the A. visit johnnypopper.com there is a comparison chart for all letter series.
Maark
04-30-2005 12:43:00
The AR is a standard tread version of the model A. First built in 1935, continued until 1952. It remained unstyled until 1949. The AR was going to be called the AS for A Standard until someone at Deere figured out that the Model B Standard or BS would get a bad rap. The letter R stood for regular tread, instead of S for standard tread. Engine components are the same as the rowcrop tractor. First AR was built on 4-27-35.
Dave in Ohio
04-30-2005 12:41:49
The AR both styled and unstyled are just the wheatland version of the John Deere A. They were made for plowing and discing but not for rowcrop implements. Lower 26 inch tires. You will find specs for the AR in the JD A parts manual and the AR owners manual.
