5020 24 V. elec.
Ronnie L.
04-29-2005 16:45:50
Is anyone on the board knowledgeable on this subject?
buickanddeere
04-29-2005 17:15:50
 Re: 5020 24 V. elec. in reply to Ronnie L., 04-29-2005 16:45:50
Yes. Do you have a muiltimeter and wiring digram?
Ronnie L.
04-29-2005 20:06:24
 Re: 5020 24 V. elec. in reply to buickanddeere, 04-29-2005 17:15:50
Yes, I have both. I have two problems with the charging system. # 1 is the charge indicator light will not work because it is not getting the proper ground from the alternator. I should mention this is the alternator with the regulator attached to the alternator. The other problem is the alternator will not charge when installed on the tractor yet it has been tested by two different rebuilders and they both confirm it is working. I have done extensive testing on the system and can not pin point the problem.
msb
04-29-2005 20:23:22
 Re: 5020 24 V. elec. in reply to Ronnie L., 04-29-2005 20:06:24
Check all the connections on the quick disconnect under the hood and also check to see they are in the correct slot.
Once had to do a Deere program upgrade on a 5010(installed an alternator).Same problem as you are experiencing.Two John Deere service engineers and I worked for 2 or 3 days finding that one wire in the harness was routed wrong for an alternator.The system worked fine when the tractor had the old generator on it.
Ronnie L.
04-30-2005 04:03:34
 Re: 5020 24 V. elec. in reply to msb, 04-29-2005 20:23:22
I have checked all of those connections. The indicator lamp will work if I ground the wire from lamp to regulator. To me this would indicate a problem in wiring of alternator or regulator.
