hogman 2002 Crankshaft
Earl-IL
04-29-2005 16:35:08
Did you find a grinder ?? Earl
hogman_2002
04-29-2005 20:43:18
 Re: hogman 2002 Crankshaft in reply to Earl-IL, 04-29-2005 16:35:08
Well, we ended up just ordering a new crankshaft from John Deere.
I went to Crankshaft and Valve on Tuesday to see if they would grind it. Talked to the head guy who miked the #4 rod journal and he said it would probably have to be ground .030. He also said he couldn't guaranty the crank if he took off .030. So I decided to just get a new one from JD.
He also said John Deere doesn't make their own crankshafts anymore. Said they are aftermarket ones just sold by JD. Is there any truth to this?
Earl-IL
04-30-2005 08:54:16
 Re: hogman 2002 Crankshaft in reply to hogman_2002, 04-29-2005 20:43:18
Crankshafts are a real problem.The quality of aftermarket cranks bother me. Did Deere tell you they guarantee crankshafts?In fact I don't know anyone that does. Other than the fact it is the correct size.The after market cranks are only guaranteed that they are correct size. After you install it and checked all the clearance you have accepted it. Did you try to find a orginal good used crank and have it reground? Make sure you have a good shop check the big end of your rods and replace the rod bolts. Why did your crank fail? Earl
hogman_2002
04-30-2005 22:14:31
 Re: hogman 2002 Crankshaft in reply to Earl-IL, 04-30-2005 08:54:16
The crank failed because the guy who owned the combine before me ran the motor without oil. The oil drain hose rubbed a hole in it and leaked all the oil out. The guy didn't know it until he heard the engine start to knock. We bought the combine with the blown motor but didn't know how serious it was. We did try and find a used crank from some salvage places but they all wanted from $850- $1250 for one. Then after you add the cost of having it ground, which would be another $225, we decide on a new crank.
Earl-IL
05-01-2005 13:14:46
 Re: hogman 2002 Crankshaft in reply to hogman_2002, 04-30-2005 22:14:31
Sounds like used parts are getting higher all the time . I am sure you made a good choice. Good luck on your project. Earl
