Cylinder head bolt
Green '52'
04-29-2005 16:16:30
Tractor is a '52 B, 201000 and up. I would like to know if I have more trouble than only a stripped bolt. The bolt is holding down the exhaust manifold to the cylinder head on the fly wheel side. I had a broken lock washer on the bolt and was going to change it. I found the bolt into the cylinder head was stripped. I had anti-freeze run out of the bolt hole. My question is, why is the anti-freeze running out and if it suppose to, how do I seal it?
Thanks alot for any feedback.
Bob
Larry806
04-29-2005 18:19:05
 Re: Cylinder head bolt in reply to Green '52', 04-29-2005 16:16:30
Those bolts extend in to the water jacket You will have to drill it out & heil a coil the hole I use a sealer on the bolts when I install them
