37 A gas valve
Cornhead
04-29-2005 11:37:45
I now have a beautifully restored 37 A John Deere, but with one small item left to restore. I need a seal kit for the three way brass gas valve. Does anyone have a source for this? Please HELP????
randy hall
04-29-2005 18:18:54
 Re: 37 A gas valve in reply to Cornhead, 04-29-2005 11:37:45
i just got two of them today from our local john deere dealer. they had them in stock.
John T
04-29-2005 15:29:25
I think I bought my last outer packing/seal which goes on under the big outer jam nut direct from Mother Deere, but can tell ya this. I buffed n polished the inner cone and then lapped it into the bore, got her into the big main fuel tank position (we never use the small starting gas tank anyway) then tightened her down tighter than Dicks Hat Band and theres no leaks and I NEVER MOVE IT cuz thats a good place to develop a leak. My sediment bowl has the shutoff I use cuz Im not gonna turn that shiny pretty NOT LEAKING brass 3 way valve ever.
John T
Maark
04-29-2005 15:23:06
 Charlieflatswater in reply to Cornhead, 04-29-2005 11:37:45
your fuel valve is marked at each position,K for kerosene{large tank} G for {small tank} and O for off.
charlieflatswater
04-30-2005 05:19:43
 Re: Charlieflatswater in reply to Maark, 04-29-2005 15:23:06
maark,
thanks for the information--- the lines look as though they have recently been replaced along with the valve and there is teflon tape on the fitting attached to the carb. so i'm assuming it hasen't been too long ago that it's been worked on. i just got this tractor --she is a honey! the guy unloaded off the trailer and drove it up in my driveway. after he left i tried to start it and the thing wore me out quick! then i checked the fuel in the small tank---it was dry!!! i filled it up and by this time i was rested up and i cranked her over and it started right up!! i took her for a spin down the street about two blocks and came back ---- it was idling for about five minutes and she shut down???? i thought--did it overheat???? well, she was out of fuel again??
i guess the small tank's capacity isn't much?? so, i put some gas in the large tank but never got her to run on the large tank--- i'll look for the letters next weekend when i get back upstate to play with her... thanks again for the info,charlie
ps: considering how hard it is to turn them over - are they always easy to start--when hot-cold etc??
Bobl1958
04-29-2005 13:02:08
K&K has them if you can't find any anywhere else. Bob
Cornhead
04-29-2005 12:17:51
I'm suspecting the parts guys at the dealership i went to just really didn't get too concerned with my request. Thanks to Mike M for the part number....i very much appreciate it. Sounds like my problem is solved.
charlieflatswater
04-29-2005 12:10:52
cornhead,
i have a nice 1937 --just got it! question: the three way fuel control valve is "off" when pointed at nine o clock. and fuel from the small tank when turned down or six o clock. which position is correct to draw fuel from the large tank????? ?? i guessed that it would be the three o clock position, but it shut down after a minute? thanks, charlie
Cornhead
04-29-2005 12:02:38
the two dealers I spoke with tell me this is no longer available
Mike M
04-29-2005 12:10:55
 Re: 37 A gas valve in reply to Cornhead, 04-29-2005 12:02:38
Part number D2123R comes to mind ? That should be the packing.If it is get several as you will need to change them every so many years.
YOUR JOHN DEERE DEALER !!
04-29-2005 11:54:44
