430 TOM check valve issues--have one to sell me?
Roger Bultman
04-29-2005 10:00:09
TOM goes down a bit, then back up. I suspect tom check valve is bad.
Can these be removed and cleaned/re-conditioned?
I called Deere and new is 250.00 for the 2 stage check valve.
Can I get used if needed? Do you have one to sell me?
Thanks for your help.
Roger
Henry J
04-29-2005 11:23:39
 Re: 430 TOM check valve issues--have one to sell m in reply to Roger Bultman, 04-29-2005 10:00:09
Roger
It doesn't sound like you have taken the unit apart yet. Here is my two cents. The book does referr to check valve problems if your tom is doing that jinking deal. Mine did it also.
When i pulled mine apart, i found that the part of one of the control valves that the end of the check valve rides on was grooved, especially where the check valve rides up on the ramp. There aint no way to fix that except starting with another control valve. I found a good one for as i recall $25. Then you can do some work on making sure the valve is seating and adjusting the clearance between the check valve and the control valve.
However that calls for disassembley.
I think you could always pull them out and look for obvious problems like corrosion or bad seats, etc.
Get back with us when you decide which way to go.
good luck
Wayne in Tn.
04-29-2005 11:06:31
Roger, the manual says when rebuilding the TOM use a small amount of valve grinding compound with a screwdriver in the slotted end. Lap the seat good then clean out the leftover compound.
Roger Bultman
04-29-2005 11:14:03
 Re: 430 TOM check valve issues--have one to sell m in reply to Wayne in Tn., 04-29-2005 11:06:31
Wayne, do you need any special tools to do this?Thanks for your help.
Roger
Wayne in Tn.
04-29-2005 17:56:40
 Re: 430 TOM check valve issues--have one to sell m in reply to Roger Bultman, 04-29-2005 11:14:03
Roger, no special tools are needed, just roll the screwdriver back and forth between your palms. One other thing to check on the jerking up and down is the draft control. Try holding the adjusting rod back with your hand and see it the jerking stops. Some have a small spring on them for this purpose.
