Deere 111 - Engine Removal
Steve Daugherty
04-29-2005 09:07:56
Greetings,
I recently aquired a Deere 111 with the 11 horse Briggs engine through a trade. The previous owner advised that it had a pretty good oil leak on the lower end of the engine. You can see evidence of oil all over the lower quad of the block but no direct "I'm leaking here" spot.
Last night, I took off the hood and gave it a quick look-see. Thought it would be wise to ask someone with some know-how to see if there is a "right" way or should I just keep removing things until I get the engine out.
Before I get it too far down, I'm gonna try to fire it up to see if I can't isolate where the leak is.
Related - What's the "right" way to pull the mower deck? I think I could access the underside engine mounting bolts better with it out of the way.
Thanks in advance!
Steve
RalphinWI
04-29-2005 20:18:51
 Re: Deere 111 - Engine Removal in reply to Steve Daugherty, 04-29-2005 09:07:56
I would check the gasket(?) between the oil filler (plastic pipe) and the block. A screw driver operation. Mine leaked there rather badly, replacing it solved the problem for 6 months, then the bottom seal on the crankshaft went. I normally don't monkey with crankshafts, but I replaced that seal and a new crankcase gasket. No leaks after two years.
Maark
04-29-2005 15:26:13
There was a sevice bulletin 20 years ago on that motor. The gasket between the bottom and the top half of the engine would squeeze out of place. All it needed was a new gasket installed.
Steve Daugherty
04-30-2005 09:21:09
 Re: Deere 111 - Engine Removal in reply to Maark, 04-29-2005 15:26:13
Thanks for the responses folks.
Re: Pressure washer. would sure be nice but I dont have access to one. I"ve pulled the mower deck, removed the muffler (and pipe) and cleaned some of the gunk off.
Re: The upper and lower block gasket...That"s where the fellow that had it before advised that it was leaking. There"s a lot of oil on the pulley"s so I think I might be in for the crankshaft seal too. How far does the engine have to be disassembled to get to the crank seal?
Re: Filler tube issue. No such luck. This version doesn"t have a dipstick. Just a screw off cap.
I"ve checked the Deere site and based on the exploded parts diagram I"m thinking that I"ve got to unbolt the large bolt that connects to the crank to the largest pulley to eventually get the engine out. Am I right?
Thanks again in advance,
Steve
Steve daugherty
04-30-2005 13:01:06
 Re: Deere 111 - Engine Removal in reply to Steve Daugherty, 04-30-2005 09:21:09
Disregard last re: crank seal. Got the engine out and the lower block off. I see the crank seal.
There was hardly any gasket there at all.
Re: Reassembly. The oil slinger. Is it better to position the arm on the gear spindle and try to slip the slinger assem. into the pan or to have it in the pan and try to slip the arm on the spindle in the engine?
Thanks again,
Steve
old
04-29-2005 09:44:14
I'd preassure wash it before going any farther. Then start it up and you maybe able to see the leak. Most of those old mower decks drop off with just a few pins pulled.
