630 DECAL PLACEMENT
TIM
02-22-2004 09:58:51
Just finished my 630 restoration and can't quite figure out where exactly the 120hr service/oil weight decal goes. K&K decals which are excellent, but the paper they send with them leaves a lot to be desired.
MIKE HANLEY
02-22-2004 10:40:01
 Re: 630 DECAL PLACEMENT in reply to TIM, 02-22-2004 09:58:51
When we redid our 630, I had the same question. JD didn't always get it right eather. In the ops manuel on page 67 it shows the Prower Trol decal below the dipstick/filler hole. But on page 34 it shows this decal on the power Trol valve housing, just below the top cover. I put that decal under the dipstick/filler hole as that is where I remember it going. As to the service decal, I recall it being on top of the crankcase, in the corner just ahead of the distribtor. There is one picture in the manuel that shows no decal in this area,I still put it there as that is where I recall it beening, so it could be read when you bent over to pull the engine dipstick. As to the rest of the placement of decals, I went to the basement and scaled off a pression Ertl model. PS: on the Ertl 730D pression model it shows the service decal behind the cluch fork on top of the crankcase becauce the engine oil filler on the 730D is where the decal would go on the 630.
TIM
02-22-2004 16:41:39
 Re: Re: 630 DECAL PLACEMENT in reply to MIKE HANLEY, 02-22-2004 10:40:01
Yeah, I notice the same thing on the powertrol, and I opted to put it where you did. I figured that the service decal went where you said, but I was not sure.
