1050 2 STAGE CLUTCH
G2 DEERE
04-29-2005 06:10:33
IS THERE ANY REASON WHY MY WHEEL DRIVE WILL DISENGAGE ON THE 2 STAGE CLUTCH AND MY PTO CLUTCH WILL NOT. CAN THE CLUTCH AND PRESSURE PLATE ARE STUCK TOGETHER.
RickB
04-30-2005 11:44:15
 Re: 1050 2 STAGE CLUTCH in reply to G2 DEERE, 04-29-2005 06:10:33
If the transmission disc is worn thin the PTO disc will not disengage.
Mark P
05-06-2005 04:56:46
 Re: 1050 2 STAGE CLUTCH in reply to RickB, 04-30-2005 11:44:15
How do I find out what the spec thickness is for the clutch material? Is there a standard thickness for most Deere tractors? I am thinking of getting the clutch disk relined and don't want to end up with stackup problems.
Mike M
04-29-2005 06:27:12
Your pto disk is more than likely stuck. Hook it up to a dyno and hold the pedal down and see if it will break free before the engine dies. If you do get it loose lock the dyno down tight and slip your pto clutch some this will help keep it from resticking. I have had good luck with freeing up drive clutches and then slipping it in high gear with the brakes on and engine full throttle,this shines them back up again. I have not done any pto ones yet but should be similar.
