JD 110 (1970's) leaking fuel out of air cleaner!
Jason Z.
04-28-2005 22:04:13
Howdy all.
When I moved into my new house last fall, I bought the previous owner's John Deere 110 Riding mower too.
He told me that it had been refurbished by a
local JD service shop recently.
I think this model is from the late 1970's.
(How can I tell exactly?)
It has a Kohler motor, and the carb/air cleaner
are on the very front under the headlights.
The last time I used it, it seemed to run fine,
but there was a strong gas smell.
After poking around, I realized that the air
cleaner was soaked with fuel, and it was dripping
down to the frame every 10 seconds or so,
eventually leaving a small puddle on the ground.
Does this carb need a rebuild? Or is there
some simple thing I can adjust to stop it from dripping?
Thanks!
-Jason Z.
Maark
04-29-2005 15:31:10
 Re: JD 110 (1970's) leaking fuel out of air cleane in reply to Jason Z., 04-28-2005 22:04:13
If it has a tecumseh motor, there is a spring loaded drain valve on the bottom of the bowl. Inside the bowl on that pin is a small round rubber gasket. It has more than likely swelled from alcohol in the gas and need replaced. very easy to do. Same part from a LawnBoy push mower will work.
Bob
04-29-2005 05:48:29
There may just be a little piece of crud in the carburetor's inlet valve (needle and seat), or, as the other poster says, the float could be damaged.
If it is a Kohler engine, you can find detailed carburetor instructions at this link (in .pdf format). If it is a Tecumseh engine, the Kohler carburetor instructions will still apply (more or less).
Link
(The carburetor sevtion begins on page 27.)
For tractor serial number information, try this link:
http://www.weekendfreedommachines.org/
John T
04-29-2005 08:42:15
 Re: JD 110 (1970's) leaking fuel out of air cleane in reply to Bob, 04-29-2005 05:48:29
Yo Bob, thanks for posting that Kohler link, I downloaded n saved it.
John T
Mark Scholten
04-29-2005 04:10:19
Sounds like a float problem. You may have a small pinhole in the float and it is letting the fuel level to be to high. Same as flooding. Take the float bowl off, go to your local small engine shop and they will hand you a new float and bowl gasket. Replace it and you should be all set. Mark
