JD 2010 Marvel Schebler Carb
Green Bean
04-28-2005 20:01:45
Any tricks to rebuilding a 2010 carb or is it pretty straight forward? It has been sitting a while and I can't get any gas to the bowl but haven't taken it apart yet. Is a simple kit the answer or does it sound major? Does anyone know what the starting settings are for the adjusting screws on this one? Thanks for any help.
Believer45
05-04-2005 18:50:33
 Re: JD 2010 Marvel Schebler Carb in reply to Green Bean, 04-28-2005 20:01:45
I had a similar problem with mine. The O ring in the adjustable jet that mounts on the bottom of the fuel bowl was bad and the inside of the carb was gummed up. Took it apart, cleaned everything and got an O ring that fit from the local auto parts house for a couple cents. It has run like a deere for a year or so since. I re-used the gaskets since I did not have a kit and nothing leaks.
Dave / Believer45
billde
04-29-2005 03:31:17
Forgot to mention, the idle jet and load jet are the same thread but different orifice sizes. Idle goes in top half of carb, don't get them mixed up. Let us know which has the larger hole and I'll write it down in the service manual for future reference.
billde
04-28-2005 20:26:10
You have an inlet screen attached to the inlet elbow, sounds like it's plugged or the needle is stuck in the seat. one turn on idle, two turns on load. Make sure all the idle circuit holes are open, these are the holes in the bore of the upper half.
