1945 JD model B 3-way fuel petcock
Keith JD man
04-28-2005 17:05:43
Well you guys have helped me before , so here goes , another one. On my "45 B I went to start it for the first time this spring, and the s way valve was very loose, well it turnd out to be the larger sucuring nut was loos is all. NOW here"s the issue before i discovered that it wasnt much to remedy I took the connecting rod off , and the stop index also , and after that I turned the main shaft several times in both directions thinking i was freeing it up, well gentlemen In my infinite wisdom I in turn , rotated the shaft enough , so as not to know now the position for it to be in , to correctly indicate when it"s off, on the small tank and ,adjusted to the larger tank. Does any one either have, a schematic, of the internal workings of this valve??? or can any one tell me how to adjust this lil bugger back to the original setting????? Once again thanks for your help.
Maark
04-29-2005 15:37:29
 Re: 1945 JD model B 3-way fuel petcock in reply to Keith JD man, 04-28-2005 17:05:43
Sorry wrong post.
Maark
04-29-2005 15:36:28
Your fuel valve is stamped with a K ,G, and O for off
Mike M
04-28-2005 18:18:21
The big tank is F-uel the small tank is G-as put some in one and turn the valve until it runs out then you will know where to index it.
