How to remove Model H flywheel cover
Ravgardner
04-28-2005 17:01:25
I'm working on removing the flywheel cover on the Model H, although I have not gotten radical with it yet, I'm hoping someone will have a "Magic Bullet" of an idea that will make this easy.
As I see it, it has to be bent, streched and pryed off sort of like removing a tire. But this steel stuff does not strech very well. Also, I'm wondering if it is best to take if off while the flywheel is still on the tractor and held steady? But it doesn't look like there is enough room to take it off the back and the straps that bolt it on would keep it from coming off towards the outside.
It would be greatly appreciated if you all could give me a hand.
Pat Browning
04-30-2005 08:50:59
 Re: How to remove Model H flywheel cover in reply to Ravgardner, 04-28-2005 17:01:25
Hey Guy -- When you have that thing figured out, please drop me a line to tell me how you managed to make it happen. My email is [email protected]
jdhbag
04-28-2005 19:06:29
Loosen or remove the two bolts on the back of the flywheel that clamp it to the crankshaft. Drive two wedges or cold chisles in the slots by the crankshaft and it should pull off easily. If it is electric start you will have to remove the flywheel cover that covers the ring gear. Good luck.
Mike M
04-28-2005 18:20:29
It's been awhile,but that prying twisting and scraped paint does sound familar ?
