620 intake and exhaust manifolds needed
Kywookie
04-28-2005 08:02:26
I have a friend who is in need of exhaust and intake manifolds for his 620. From what I have gathered by browsing the forum this is a common issue. What I did not discover is how does the aftermarket manifolds compare to genuine JD parts (if still available). There are a few vendors on Ebay that offer repops but I wanted to hear how they compare before making him a suggestion to go that route.
Thanks.
buickanddeere
04-29-2005 08:22:30
 Re: 620 intake and exhaust manifolds needed in reply to Kywookie, 04-28-2005 08:02:26
Install with 1500 F never-sieze on the threads and heat riser valve. If the operator isn't running her at max power in hot weather. Turn the heat valve to "Hot". Don't place the valve between hot and cold. Make certain the head surface is flat. A leak there is hard to find, makes the idle rough and allows dirt into the engine. Use a torque wrench on the bolts. And educated guess contributes to manifold leaks and blown gaskets.
Kywookie
04-29-2005 17:06:50
 Re: 620 intake and exhaust manifolds needed in reply to buickanddeere, 04-29-2005 08:22:30
Thanks for the replies. I'll pass this information along to my friend.
Kywookie
Carl NY
04-28-2005 18:46:31
I have been using & selling after market manifolds for about 14 years. I have found them to be great performers at a very significant price advantage over John Deere. The 620 manifolds fit very good. If you have any further questions, you can call me @ 315-945-7138.
Carl NY
04-28-2005 18:43:43
