420T hydraulics
Jason(PA)
02-22-2004 06:12:12
My neighbor just got a 420T with very weak hydraulics. They go up and down just fine and they even can lift a heavy implement just fine,but the problem is it won't hold anything at a constant level. It gets worse as the tractor runs for a while and gets hot. Is it a major operation to fix this? How hard is it to tear into the hydraulics of one of these? Thanks for any help!
JASON(PA)
RUSS
02-22-2004 16:47:54
 Re: 420T hydraulics in reply to Jason(PA), 02-22-2004 06:12:12
420T Challenge; Clean and inspect all parts during the tear down. Keep in bowls and/or containers.
Go over the SM info several times to commit it to memory and weave the reality as it is examined with the Part manual sketches. If you follow the advice of the other threads on this issue you will succeed. Good luck.
Henry J
02-22-2004 15:16:30
Jason
Gazing into the fog, I think I remember that the jinking up and down, according to the manual, could and should be the Check Valves. They can be pulled out the side without disassembly.
But the check valves ride on the control valves inside. In my case one of the check valves that wasn't working right wore a groove in the ramp on the control valve. Now you are looking at a complete dissassembly to make sure the control valves are ok.
Sigh, we are back to where Mike and Wayne started. Good Luck and have fun!
MIKE HANLEY
02-22-2004 06:35:45
I wouudn't even think about it til after I studyied the shop manual (SM2019). It takes 31 pages in the SM to cover the hyds on a 420/430. and have the parts book (PC-505) in the other hand. It maybe something as simple as an "O" ring, but you have to get to it and these systems are "differant".
Wayne in Tn.
02-22-2004 08:31:11
 Re: Re: 420T hydraulics in reply to MIKE HANLEY, 02-22-2004 06:35:45
Jason, I average rebuilding those units, on the order of about 2 or 3 per year. As mentioned, there is no need to start without the Service Manual and the Parts Manual. These units are a different animal from the hand clutch tractors. First, there are no easy and quick 'fixes' Get the manuals, then set your mind for a complete tear-down. Because this is necessary to get to anything that is causing the problem, then once its torn down, might as well do a good cleaning and replace all the 'soft' parts such as piston seals, head seals, o-rings, gaskets, ect. These parts will cost about $150 from Deere. It's fairly simple to do, once you have studied the manuals, and have become familar with the parts and thier functions. Let me know if you start the project, I will be glad to help anyway I can.
Jason
02-22-2004 16:01:38
 Re: Re: Re: 420T hydraulics in reply to Wayne in Tn., 02-22-2004 08:31:11
Thank you so much for your input! I can tell just by looking at these hydraulics that they are a different bread. My neighbor does have the shop manueal and we have been looking at it trying to build up the courage to dig in. It will probably be a few weeks before we start so I thank you for offering you help!
