2840 pros and cons
Gary in TX
04-27-2005 11:37:10
Hey guys, I have opportunity to acquire a 2840 worth the money wiht a 148 loader on it. Anybody got any pros or cons about the tractor.
j cook (iowa)
04-28-2005 08:23:16
 Re: 2840 pros and cons in reply to Gary in TX, 04-27-2005 11:37:10
I was once informed that a 2840 was NOT recommended as a loader tractor. I think that one of the reasons was hydraulics and the other was a not tough enough chassis for mounting most loaders. The 2940 is supposed to be the improved version suitable for loader work.
madcow
05-01-2005 10:25:16
 Re: 2840 pros and cons in reply to j cook (iowa), 04-28-2005 08:23:16
the 2840 along with most of the 2000 series tractors are a good tractor for a hobby farmer. they can give some trouble in the rear clutch housing were the charge pump and lines are. they are known for them lines breaking. also have seen a lot of the parking breaks fall apart.
Cory R.
04-28-2005 07:47:02
Pice of #### my brother works for a john deere dealer and nothing but trouble hydrolics are natorus for problems transmission problems gallor. By a 2940 it is the revised verison of the 2840 it was better built we own a 1981 2940 and it dosent owe us a dime. dont by it if you ask me.
Bought a new one in 1979
04-27-2005 18:13:50
Adequate tractor with one exception. The transmission pump is not big enough. Trans pump (gear) will not supply enough oil to the piston pump. The hydraulics therefore chatter, the piston pump cavitates and the oil runs hot because the excess flow (of which there isn't any) is what goes through the oil cooler.
no.2
04-27-2005 17:34:53
We had one. A very good motor and tranny. It was easy to operate, plenty of power but once we started haveing hydraulic problems it became a money pit. At about 7000hrs it became really costly to repair. We traded it for a 4320 and I would not trade back. Also we were told the 2840 didn"t really have enough frame for most loaders so we found a 4020 with a 158 loader. We put a front end from a 4640 and a pump from a 4440 on the 4020 and it"s a pretty strong loader tractor now.
no.2
04-27-2005 17:34:58
Mike M
04-27-2005 11:42:29
If it is in good shape and if it is the size you need get it. I think they are fine. They are just too big for some and too small for others.I think most people needing a tractor that size also want more HP so they just buy a 4020.
Gary in TX
04-27-2005 12:00:18
 Re: 2840 pros and cons in reply to Mike M, 04-27-2005 11:42:29
Thanks, I have a 3020 with a 48 loader that I was thinking of replacing with it. For hay loading, square baler pulling, disking and other odd jobs. I'll know more about it hopefully by in the morning.
cannonball
04-28-2005 03:38:51
 Re: 2840 pros and cons in reply to Gary in TX, 04-27-2005 12:00:18
gary let me know if you don't want it and where it is thanks .....
