Dave, I doubt you need any ground wire to the switch, more likely a hot voltage feed which gets transferred to the solenoids engage terminal in order to activate it. This assumes from your description youre using an electric solenoid type starter versus the manual mechanical push start switch is that correct???? On some of the old Fords and a few other one wire applications the push to start push button actually did supply the ground path for the solenoids, but I doubt if thats what youre doing. The circuit I have in mind has a minimum of a single pole, single throw (two terminals) or double throw (3 terminals) switch, be it key or push or toggle operated. The common POLE input terminal requires a hot ungrounded battery post voltage feed and then use whichever other remaining normally open terminal (one of the throws) is the one that gets hot when the switch is pushed or turned or otherwise engaged, and the other throw (the Normally closed) if it has one isnt needed. Wire the normally open throw terminal from the switch down to the solenoids activation terminal,,,,, ,have the solenoid grounded,,,,, and wire the common pole input terminal on the switch to a hot ungrounded battery post feed and youre good to go. If you wanan get even fancier, you could use an automotive OFF-ON-START 3 position type spring key switch which feeds power to the solenoid when in the start position and it could even have an ON/OFF function used to ground the mag n kill the spark when OFF but leave it open/ungrounded when ON. Good Luck John T
