D manifold question
Duane Larson
04-27-2005 10:06:54
A friend has a late styled D with a manifold which has separate intake and exhaust castings. The exhaust manifold has a casting number LOD 1981, and there is no casting info on the intake casting. He says it is not the dual exhaust manifold - I have not seen it.
Does anyone have any information about who made or sold this manifold? The intake casting is broken.
I just returned from the LeSueur MN swap meet and had a good trip - lots of stuff there. Jerry Trcka was there with examples of his restored gauges. They really look nice, and I had not realized the wide variation of white-face gauges used over the years.
Glen in TX
04-28-2005 00:04:05
 Re: D manifold question in reply to Duane Larson, 04-27-2005 10:06:54
Yep, probably aftermarket LP or gasoline manifold. I've seen them on some Ds on LP. Some old 1950 & 1951 Implement & Tractor Catalog File books I have show ads for gas and cold LP manifolds and aluminum pistons made by Johnson Machine Shop of Pontiac Illinois. Also ad on pistons, manifolds, and other add ons made by Heisler Mfg. Co. of Hudson, Iowa. The 1951 Johnson ad shows two manifolds and some pistons for JD but that's all. Would be nice to find more catalogs or literature on their companies. Have you ever seen the high compression donuts that fit inside the D blocks? Never figured out who made those?
Duane Larson
04-27-2005 17:47:49
Thanks for the leads, guys! I think Rosewood makes only dual exhaust manifolds and he says it is not a dual exhaust system. Bob-Wyo, I'll check on your leads - I have a number of old tractor supply house catalogs and will look-see what might be in there for the D. If I learn anything interesting I'll post back. FWIW, he claims there is no hint of a starting tank ever being attached, and the dual 6-V batteries are under the hood where the starting tank would normally be. I think I need to go see that tractor.
Thanks again!
Bob-Wyo
04-27-2005 13:48:13
Hi there Duane, what he has is 1 of the after market cold manifold's, by who I havn't a clue. Deere made one too,(don't have the part # with me) but it has a legit JD num. I have orderd 3 and each time I got a after market one. Does the intake bolt on to the side of the exhaust with 2 or 3 5/16 bolts? I finnally gave up on getting the real JD one and am now running a LP mainfold with great results.
Duane if I can help more just email me.
Take care guy,and thanks for all the great info you have put out on this board. Bob
Mark Scholten
04-27-2005 12:50:54
Rosewood makes the manifold for the dual exhaust set up. You should have either a D 1891, D 2734 or a D 3412 on there. This is the exhaust manifold only. The intake is a seperate manifold.
Mark
Mike M
04-27-2005 10:12:19
There was or still could be a company in Ohio called I think Rosewood Machine ? They made D manifolds of some sort. Maybe I can find the number and you can call and see if it is one of theirs.
Jason Z in MO
04-27-2005 12:00:40
 Re: D manifold question in reply to Mike M, 04-27-2005 10:12:19
Thought I would check switchboard.com and found a Rosewood Machine and Tool
6492 Kiser Lake Rd
Rosewood, OH 43070-9997 Phone: (937) 362-3871
Hope this helps,
Jason
