Heard from others that their machine is a sloppy starter. My newly acquired one was too. Hmmmmm Yesterday I decided that was the project for the day.Findings: 2ea 6v batteries wired in series for 12v. Ground on the rt side of tractor at bolt that also holds cab heater hoses. Real pukey. Long crummy current path back to the starter. Hot lead from rt battery goes over under the cab to one side of left battery. Left battery connects to starter solenoid input. Wires were 0-00-2 respectively and the terminals were lead to lead. So with this rig, the internal resistance of both batteries is in series with the starter.....Hmmmmm pukey. New arrangement. 2ea 12v batteries wired in parallel; 900 cca, OTR truck type 31 which is a 27 with stud terminals. Fit the boxes perfectly. Now I have 12v (doubled the voltage per battery) and halved the battery resistance which should (does) make for much higher current availability. One could say (argue) that the resistance is a wash but I don't think so. Even if the 12v batt had 2x the internal resistance of the 6v, I have 2x/2 or still half the original resistance since they are wired in parallel. All cables are 00 with factory equipment crimped heavy duty lugs. Installed batteries so that both wires are 68" long connecting the batteries (one had - forward the other +). Opened the access plate under the cab (to get at them) and routed them from one side to the other. Not a problem. Did install anti-chafe sleeve over these wires and the dealer had that too. Took one starter mounting bolt out and shined up the case of the starter and reinstalled with ground lug (-) from left hand battery and new bolt. Ground lug is now directly connected to the starter. Connected + lead of left hand battery to solenoid input. These cables were 25" and 14" respectively. Now I have at least one 900 cca battery with 00 wiring that is a max of 39" total length of wiring, connected at the batterie(s) with 3/8 studs and nuts, connected to the starter. It's current doesn't have to go thru anything but the starter. The second battery is also directly connected to the starter, but the line drop will be (is) slightly higher due to the length, but not much with 00 wire. Don't have to tell you the results. Well worth your time and $$$. Could save your starter (from grinding and grinding) and that alone would cover the cost of all the parts for this. I spent $205 for everything. Besides, when is the last time you replaced your batteries? Other thing I noticed is that it's (my 4230)more responsive to the throttle sitting at idle or just barely off when starting than the 4010 for example. Makes the old girl sit up and pay attention. Mark
