Clutch Cover
tsmith1499
04-26-2005 20:28:58
Okay guys, give me a hint. I bought a new clutch pulley cover for my 720D. I can't get this thing on to save my life. I don't want to beat it to death putting it on. Is the little clip in the pulley drum supposed to clip over the lip of the cover. if so I need to bend it up a tad. Thanks, Tom
budkeye al
04-28-2005 10:00:46
 Re: Clutch Cover in reply to tsmith1499, 04-26-2005 20:28:58
The nose of your retainer clip is resting soundly on the pulley isn't it? Part of it has rusted away & the spring clips are not rising up over the rim of the cover as you push it into the pulley. They're supposed to have a leader that the cover slips under (between the clip and the pulley) allowing the clip to snap back down over the rim into the recess in the cover's rim. Get some new clips and rivet thm into the pulley and the problem will be gone. Had to do this on both an A and my 70D.
Good luck.
tsmith1499
04-28-2005 14:46:06
 Re: Clutch Cover in reply to budkeye al, 04-28-2005 10:00:46
THANK YOU!! I knew there had to be something weird about that setup. Yes, it does appear as though the leading edge of the clip is gone. The clip points striat down toward the pulley. It has no "leading lip" at all. NOw all I have to do is look thirough the parts book and see if they are still available. Thanks budkeye! Tom
buckeye al
04-29-2005 13:56:34
 Re: Clutch Cover in reply to tsmith1499, 04-28-2005 14:46:06
They were 2 years back when I put new ones in my 70D.
Careful when riveting them into place. I bucked them with a short jack & a piece of bar stock then heated the rivet from the outside & finished the riveting. Nice & tight.
Good luck.
Mike M
04-27-2005 05:42:46
Yes those 3 flattened spots get indexed with the adjusting nuts.
tsmith1499
04-27-2005 16:08:43
 Re: Clutch Cover in reply to Mike M, 04-27-2005 05:42:46
I understand that. My problem is that little clip inside of the belt pulley doesnt want to go over the lip of the cover.
