JD 2640
Dave Sherburne,
04-26-2005 19:00:01
Got a 2640 total engine overhaul last winter starts and runs great. While plowing, and really lugging the engine, NO SMOKE at the exhaust never saw a diesel that didn"t smoke while working
hard . I don"t think it really has the power it should .Is it possible to adjust the injector pump
on this for more power.???
720Deere
04-27-2005 10:25:16
 Re: JD 2640 in reply to Dave Sherburne,NY, 04-26-2005 19:00:01
I don't know how much experience that you have with a 2640, but they are not by any means a torque monster. They don't really feel like 70 hp should and tend to be a little buzzy. Kinda like a rice burner, it will run fine if you keep it zinged up, but no lugging torque.
If it's not putting out any smoke on a hard pull, then you should have some room to bump up the fuel. The dyno recommendation was a good one. If you do turn up the fuel, I would do with the assistance of a dyno. Go no more than 10% over rated hp and see how that does for you.
John36bn
04-27-2005 07:39:12
Maybe put it on a dyno and see what it puts out before you do anything. If its starting, working and getting the job done within the engines specified hp range than dont go looking for a problem.
