720LP/fresh overhaul/won't start/stay running
Ben.So.Tex
04-26-2005 18:32:20
Just overhaul a 720lp,I can turn the gas on and switch and hear the silnoid open, try starting it and it won't fire off..I can wait about 3min (with gas turned off) and hit the starter and it will fire off and run..BUT as soon as I open the vapor valve on the tank it Dies.I took the regulator apart and it all looks good.It is a Century M4 regulator. What might be the problem? Ben
Tyler-MO
04-27-2005 01:25:39
 Re: 720LP/fresh overhaul/won't start/stay running in reply to Ben.So.Tex, 04-26-2005 18:32:20
Ben,
I"ve been through similar issues with a 720 and 520 tractors. You might check that the solenoid is really staying open...maybe possible that the pressure/flow is causing a weak solenoid to close. Another thing that could be causing it is...
The convertor might be sticking open causing the engine to flood?? If this is the case...though it would have to be pretty severe. I"ve had bad luck with those old M-4"s and have replaced them with the newer M6"s or an model "H" would do as well. Another thing to look at in the convertor is if the little spring inside the flow control valve/pressure regulating valve...whichever you want to call it...it"s the valve on the input side of the regulator right that the line attatches to. Be careful about removing it though...the little tip on the end can fall off in the convertor and then you"ll have to take it apart to get it all put back together.
One more thing to check...I haven"t personally had this problem...but on the fuel solenoid there is a strainer in the bowl. If you take this apart plan on using a new neoprene gasket (available from any century LP dealer) because the old one will certainly leak under full pressure. The filter is in the top of the fuel lock solenoid part...and should look like a piece of screen...they are hard to get out and be able to reuse them if it"s not damaged. If clogged it can restrict flow to the point of not having enough fuel at first and then a severely restricted flow. //If you don"t want to remove the fuel lock solenoid...just bypass it to rule out any problem...get a union for the lines and hook it up direct. If it works then your problem obviously lies in the fuel lock/strainer bowl.
Give some of these ideas a try and let me know if you find the problem. Good Luck!!
Tyler in Missouri (germany)
txgrn
04-27-2005 07:02:59
 Re: 720LP/fresh overhaul/won't start/stay running in reply to Tyler-MO, 04-27-2005 01:25:39
May not apply, but on my overhaul, I missed a sentence in the service manual that said to make the final timing setting on my tractor 25 BTDC. I had it at TDC and it was a real bear. Different engine so that number probably doesn't apply, but insuring it is correct whatever it is does.
Mark
Ben.So.Tex
04-27-2005 04:30:30
Thanks Tyler. It may be a weak solenoid, reason is that I have heard it click on and off while cranking....(This could also be caused by a bad fuse holder that I discovered yesterday with a loose connection causing it to click on and off,will replace it today)... I did take the line off the strainer at both ends and I had good gas pressure..Also with the regulator off the tractor I put my finger in the side of the carb and could feel suction while cranking the engine. suction did seem weak, But then I don't know how it is really supposed to feel. I will play with it this evening after work if time allow. I may even take the one off my other 720lp and see what that rules out. Thanks Ben.
