Dead coil circuit
Russell Montgom
04-26-2005 17:47:02
The 720 I am working on has no power from the coil to the distributer. I am getting 6 volts to the coil but it has no voltage coming from the positive terminal. I had to run a wire from the positive terminal of the coil to the ignition switch because the wiring diagram shows one. This wire is hooked to the top left corner of the switch because I could not find mag on the switch. The - of the coil is wired to the bottom of the resister. Could my coil be bad anybody have any ideas. Thanks for the help.
fixerupper
04-26-2005 20:39:51
 Re: Dead coil circuit in reply to Russell Montgomery, 04-26-2005 17:47:02
I don"t quite understand why you are running a wire from the switch to the positive side of the coil. If your tractor is still positive ground like it was originally, running a wire to the positive side will do you no good. Try running a jumper from the negative terminal of the battery to the negative side of the coil and test the coil again but make sure the points are open so they aren"t soaking up juice. If you don"t have voltage from the coil either the coil is bad or the condenser is shorting out. It could also be something weird like the terminal on the condenser being cocked and touching the inside of the distributor. If the jumper wire you put on the negative terminal makes everything work fine, then you have a weak circuit between the switch and the coil, and the resistor would be the first thing to check. With the points open and nothing shorting out you should get twelve volts to the coil through the resistor because the resistor does not start reducing voltage until it has a load running through it, like when the tractor is running. Good luck.
John T
04-26-2005 19:58:52
Russell, so many questions so little time lol.
1) You say youre getting 6 volts to the coil?? If thats so, the ignition switch is on and okay,,,,, and the ballast resistor is okay and working SO FAR SO GOOD
2) NOW IFFFFF F the points are closed, which they usually are as they only open at the firing of the pistons at TDC, THERE SHOUOLD BE NEAR ZERO VOLTS on the coils low (to distributor) side, since the points are connected to there and they are closed to dead ground, i.e. ZERO volts. I WOULD NORMALLY EXPECT NO VOLTAGE ON THE COILS LOW TO DISTRIBUTOR TERMINAL (since points are usually closed) if the ignitions is on and good points are closed and/or the ignition switch is OFF which is supposed to short that terminal out.
3) The wire on the low (to distributor) side of the coil you mentioned should be wired to the MAG terminal on the switch and its dead grounded when the ignition switch is OFF but its open to nuttin when its ON. If you wire it elsewhere its NOT right as if there were equal voltage on BOTH sides of the coil theres no current flow through it. If you cant insure its wired to the mag terminal on the igniiton switch, youre better off not having it wired anywhere except for the fact when its switched to OFF but the starter cranks, she can still fire the coil due to the ballast by pass circuit.
4) Sooooo put a test lamp on the coils high (from switch n ballast) side n turn the switch on and it should be arund 6 volts. THENNNNN put the test lamp on the coils low (to distributor) terminal and as the engine is cranked slowly the lamp should flash ON WHEN POINTS OPEN AND OFF WHEN POINTS ARE CLOSED or else shes never gonna fire.
5) As the engines cranked,,,,, ,,,,,If the light never goes off, the points are bad or not closing or not wired up,,,,, ,,,,,If the light never comes on, the coils bad/open or the points or condensor or its wirign is dead shorted.
6) If the coils primary is good/continuous, there should be continuity of around 1.5 to 2 ohms as measured in its primary between the lil + and - terminals assumign tis a 6 volt coil.
Armed with this now see what happens n post back any questions.
John T in Indiana
Larry C
04-27-2005 16:30:50
 Re: Dead coil circuit in reply to John T, 04-26-2005 19:58:52
Hey John, I have read your response, and i have a question that i get different answers. Does the wire to the dist connect to the (+) or the (-) side of the coil. thanks
John T
04-27-2005 18:32:12
 Re: Dead coil circuit in reply to Larry C, 04-27-2005 16:30:50
On POSITIVE ground tractors, such as 2 cylinder Deeres, where the distributors points lead to frame ground, wire the coils + terminal to the distributor when using 6 volt coils, whether its a 6 volt tractor or a 12 volt tractor that uses an external ballast resistor and a 6 volt coil. A negative ground tractor has the coils - to the distributor.
John T
