3020 lost reverse
cktate1957
04-26-2005 15:50:32
I rebuilt the motor on this tractor last winter. A few years ago I had the JD dealership rebuild the transmission (sycro range). Earler I was moving dirt with a box blade. A couple of times when i put it in reverse it screached for just a second when it went in gear. The third time when I start to let the clutch out all it will try to do is screach. I tried both reverses and easing up on the clutch, a couple of times. And then I quit. I would sincerely appreciate any ideas on what to start looking for.
Thanks.
ET
04-27-2005 05:19:54
 Re: 3020 lost reverse in reply to cktate1957, 04-26-2005 15:50:32
You probably won't see much just pulling the cover. Reverse is the rear syncronizer on the top shaft. The problem area is going to be the teeth on the inside of the syncronize drum and the reverse range drive collar. Whoever worked on that transmission in the passed may have concentrated on the high and low syncronizers for the forward gears because they are normaly the most used and the most worn. I think if nothing is obviously broken and ajusting the linkage won't help you need to bite the bullet and pull the top shaft out and have it gone through.
Bob
04-26-2005 16:08:45
Probably a broken shift fork on the top shaft, or synchro clutches worn so bad they've slipped out of place, and are blocking the shift collar from engaging the splines. Or a combination of worn shift fork and worn synchro clutches.
cktate1957
04-26-2005 20:58:50
 Re: 3020 lost reverse in reply to Bob, 04-26-2005 16:08:45
Thanks. I"m gonna take the top plate off in the next few days to see what I can see. Kinda upsetting cause I spent a bunch of money on this transmission about three years ago and told em to fix everything that was wore while they were in there.
I replaced the shifter a while back and today checked the linkages again and in all other gears except the reverses it is shifting perfectly. Also up until today the reverse has been shifting and doing perfectly. This happened almost all at once with just a couple of grinds, and then nothing but. I guess I"m wondering if it "could" be the shift fork or if it would more likely be the synchro clutches. I know if it"s the clutches the whole thing will have to be broken apart and fixed, I found that out today reading the archives. Would the same be true if it"s the fork or will it all have to come completely apart anyway.
Thanks.
dave arnstrong
08-28-2005 08:39:29
 Re: 3020 lost reverse in reply to cktate1957, 04-26-2005 20:58:50
I read your article about loosing your reverse's on a 3020 trans,I to am have ing the same troubles,How did you make out?Can you give me any hints
Thanx
Dave
Bob
04-26-2005 22:12:08
You have to split the tractor between the clutch housing and the transmission, if it turns out the shift forks have to come out, as that is how you access the shift rails the forks slide on.
