JD 50 pto
Maark
04-26-2005 15:06:43
I need an exploded diagram of the pto assembly on a 50. An early one. Someone took it apart and didn't put the guts back together. The parts are all in a bucket. Thanks...
buickanddeere
04-27-2005 18:07:31
 Re: JD 50 pto in reply to Maark, 04-26-2005 15:06:43
If she's apart that far that pto to trans seal may as well be replaced. Chances are either trans oil or being out of proper clutch and brake adjustment made her slip. Either way you maybe in for a fresh set of fiber plates at the very least plus seals. A parts, operators and service manual are cheap on a CD from 1-800-522-7448. You will nee dthe info for this and other service and repairs.
Tyler-MO
04-27-2005 01:34:03
Well...Ive done the same thing before and its a real good time. Not impossible though! If you are fortunate enough to have a JD dealer closeby...just ask them to print off a parts diagram for you...usually for free.
If you cant do this...then I might be able to get you a diagram.
Tyler
