Dltx bowl numbers / application
Dave NE IA
04-26-2005 13:13:50
I have a few buckets of DLTX carbs all in parts. I would like to find some one with a carb. book or chart of what bowls match different carbs. I have lots of carb. books etc, but they do not have a break down that I can find. Please post if you will, and thanks in advance. Dave NE IA
JGC
04-26-2005 15:23:38
 Re: Dltx bowl numbers / application in reply to Dave NE IA, 04-26-2005 13:13:50
I don't have a reference document.
The JD parts book for my "D" shows a substitute JD part number for the cast iron bowl which is DLT-13 and a substitute JD part number for the bronze bowl which is DLT-7A.
I am rebuilding the carb off a "B" for a buddy of mine and the JD parts book shows a substitute number for the DLT-13 bowl as well. I checked this bowl and it has DLT-13 cast into the bottom of the bowl.
Looks like JD assigned a JD part number to the carb manufacturers casting numbers.
The "D" carb has a larger venturi and throttle disk in the upper body but the bowl is the same!
These are the only 2 parts books I have. If your dealer keeps the old books, you could look up the casting numbers in his parts books for the different tractors.
Good Luck,
Jon
Dave NE IA
04-26-2005 19:34:03
 Re: Dltx bowl numbers / application in reply to JGC, 04-26-2005 15:23:38
I have a big MS book,the JD Carburetors for JD tractors & engines SM-2024, and simply must be overlooking something obveous. I have alot of 7's and the 13's. MS gave most of them entirely different numbers as well as basickly all carbuetor parts, along with the new MS numbers. I was almost sure I seen a chart somewhere, but probably not the first mistake I made in my miserable life. The DLTX's are not broke down as the TSX's etc. are. I will keep digging and if you all would let me know if you stumble across something. A special thanks Jon and to anyone else that pitches in. Thanks Dave NE IA
