4020 hyd pump leak
Todd Wiscal
04-26-2005 09:43:40
my '69 4020D PS leaks from one of the hydraulic pump caps. as you sit on tractor it is the cap at approximately 2:00 (pain to get at). i have replaced the o-ring twice and used the teflon washers from JD. piston and cylinder look fine as do the o-ring seat and threads. cap stays tight but fluid seeps from around it. i drilled a 5/8" hole in the frame plate to allow a 1/2" extention and socket to get a good torque. still leaks after running tractor a few hours. i'm going to try and find a slightly oversize o-ring today and try that. pump sounds and performs fine. ?? any tips? thanks in advance...
WTW
04-26-2005 10:55:41
 Re: 4020 hyd pump leak in reply to Todd Wiscal, 04-26-2005 09:43:40
I agree with Bob. It is one of two things and you may not like the most likely one. I have seen the piston plugs crack in the corners from over tightening them causing this kind of leak but more often it is a cracked housing. Do not over torque the plugs as all you are doing is making matter worse. 100 ft lbs is torque spec on these plugs. Try a new plug, o-ring and sheath and hope for the best. Good Luck, DW
Bob
04-26-2005 10:32:07
I have seen several of these pumps develop a hairline crack extending out from one of the piston plug holes. I hope that's not your problem, but it is sure possible!
