4630 Ether Injector
pbutler
04-25-2005 20:14:56
I have an older 4630 that just won't start below 50 degrees without ether. Runs great once it is started. I hate to use either too much but I have replaced batteries, cables, everything-just resigned to living with it.
Anyway, the ground from the ether injector isn't grounded-I have traced the wire back to a bundle but I don't want to split the bundle just to find a ground.
Temporarily I cut the wire and stuck it behind the bold holding the injector on and it worked-but keeps working lose or losing ground-not a great place.
My long winded question is where is a good place to ground that thing. I am just going to pigtail it to another wire and run that someplace where it will be solid.
Any recomendations? Warnings?
JD JimBo
04-26-2005 19:30:41
 Re: 4630 Ether Injector in reply to pbutler, 04-25-2005 20:14:56
I don't remember if the 4630 has the block heater or not, but using that or an external tank heater for a half hour or more before stating should cure your problems right up. I know its a pain to do this if you want to get up and go first thing in the morning, but I would rather pay the electric bill than the repair costs of too much either.
pbutler
04-26-2005 19:59:17
 Re: 4630 Ether Injector in reply to JD JimBo, 04-26-2005 19:30:41
I have a little 200 watt magnetic heater-do you mean clip that onto the fuel tank? I thought about that but didn't know if it would really help as the fuel in the lines and filters would be there first when starting??
Lee B
04-27-2005 04:28:10
 Re: 4630 Ether Injector in reply to pbutler, 04-26-2005 19:59:17
No, he is talking of a coolant heater often called a tank heater because it is a little tank or can with water inlet/outlets with the heater coil inside the 'tank'. They need to be plumbed into usually the heater hoses, though you can make dedicated water jacket connections where ever you like.
The neighbors 4630 has a freeze plug heater which is a type of water jacket heater that replaces what are often called freeze plugs but really are just holes in the block made so that the sand used in casting the block could be removed. The holes are then machined round and a soft iron 'freeze' plug is driven into the hole to make it water tight. Rumor has it that the plugs will pop out if the water jacket ever freezes, but that really only happens after the block cracks wouldn't you know it.
At any rate, the freeze plug heater works as described when you park it close enough to an outlet to use it. A half hour and you are ready to go. But in the field I had troubles in the middle of the summer getting her to go first thing in the morning like you say. I'd go ahead and run a seperate ground wire to the nearest 3/8 bolt and call it good. I'd also use ether if I couldn't plug it in, but wouldn't use ether if I had it plugged in.
That magnetic heater you've got would work good on the oil pan which is where it was designed to work at, but wouldn't make it start easier other than allowing the warm oil to let the starter spin it over faster. Those work real good for gasoline engines but don't fit the bill on diesel engines. What's really needed for diesel engines is heat in the cylinders, not in the oil pan.
