JD 316 eng surge problem
bboard
04-25-2005 07:05:36
My 316 riding mower surges at low rmp. I have tried every adjustment possible to the governor linkage. Would lack of fuel at low rpm cause this?
Steve Chaikin
08-14-2005 15:49:36
 Re: JD 316 eng surge problem in reply to bboard, 04-25-2005 07:05:36
I had exactly that problem. I called Thesier's, my local dealer in South Lyon, MI (credits due) and followed their instructions. It was a partially clogged main jet. Take off the air cleaner and the whole box. On, I think the left side of the carb, there is a plug. Remove the plug and shoot carb cleaner through the little red tube through the main jet orifice. Replace plug, button it back up, and run.
It worked perfectly for me. Good luck to you.
Steve
Bus Driver
04-25-2005 17:01:04
Often such surging indicates a slightly lean fuel mixture.
Henry J
04-25-2005 15:32:52
bb
I had another thought today. It all depends on how low the machine is trying to idle (or may depend on that).
I had a 18 hp briggs that did the loping deal at idle. It turned out that I adjusted the idle screw up a little and it smoothed right out. It has been running like a champ for several years now.
Henry J
04-25-2005 08:56:54
bboard
It sure could. I have seen this go on when the idle circjuit is mal adjusted or on the newer EP stuff when there is gunge in there on a non adjustable carb.
