Hydraulic Top Link
Hunter n NOLa
04-25-2005 04:18:55
I have a John Deere 6200 and I'm thinking of replacing the top link with a hydraulic cylinder. I already have a quick hitch. Is that ok or taboo...does anyone have any experience with doing that? What are the pros and cons?
txgrn
04-25-2005 17:12:45
 Re: Hydraulic Top Link in reply to Hunter n NOLa, 04-25-2005 04:18:55
I know what NOLa is and where. Been there done that. Grin
Don't know why not as long as you can hold the cylinder where you want it and operate the hyd lever simultaneously. Would save a lot of twisting if you have one tractor and do a lot of different jobs with it.
Only thing you might want to do is put a restrictor orfice in the hyd line (just a disc with a small hole in it). Deeres put out a lot of gpm's and it may run faster than you want.
I had a swather (mower conditioner) that had one in the lift cylinder. You wanted that sucker to move up and down slowly. Didn't realize that but one day I was changing out connectors and saw an orfice and took it out " Oh what's this" sorta thing. After the first operation on the first day of haying thereafter, I put it back in; I found out what it was and what it was for. Grin
Mark
msb
04-25-2005 14:22:34
I made one for the 4020 years ago.It worked so good the neighbor that borrowed it never brought it back.lol,bob
JD 5200 GG
04-26-2005 06:34:53
 Re: Hydraulic Top Link in reply to msb, 04-25-2005 14:22:34
WHO MAKES THE CYLINDERS THAT YOU CAN USE AS A TOP LINK WITH THE CORRECT CONECTIONS AT THE ENDS
Bguy
04-25-2005 13:33:48
I have the hyd. top and side link on my tractor that is used with a cat. 2 quick hitch. Put it on about 3 years ago and it works great. It really helps when using a box scraper/blade but it is handy to make adjustments with when bush hogging also. This combo is really the deal when hooking up those big cat.2 implements.
