Clutch smoke?
Dave in SV
04-25-2005 03:38:51
While my daughter was driving our '49 A yesterday, I noticed smoke coming out from the clutch drum. Maybe it was due to the way she was operating it... didn't have the clutch fully engaged as she worked her way around. Is this "normal", or is it an indication of a problem?
JGC
04-25-2005 18:22:44
 Re: Clutch smoke? in reply to Dave in SV, 04-25-2005 03:38:51
I have seen blow-by from the rings coming out around the clutch under the right weather conditions - cool outside temps. If the crankcase vent stack & it's screen offers more resistance to air-flow than the opening around the clutch, vapour will be visible.
Dave in SV
04-25-2005 19:33:58
 Re: Clutch smoke? in reply to JGC, 04-25-2005 18:22:44
... so where is the crankcase vent stack and it's screen? I haven't found it yet!
JGC
04-26-2005 14:42:16
 Re: Clutch smoke? in reply to Dave in SV, 04-25-2005 19:33:58
What model of tractor?
Jon
Dave in SV
04-26-2005 16:55:54
 Re: Clutch smoke? in reply to JGC, 04-26-2005 14:42:16
'49 A Styled
JGC
04-27-2005 12:08:06
 Re: Clutch smoke? in reply to Dave in SV, 04-26-2005 16:55:54
OOOPS,
You did say "49A" in your comments. I'm very familiar with the "D" but not with the "A". Someone with experience on the A should reply.
On the "D", there is a vertical pipe about 15-18" tall. It has a removable filter canister in a cup part way up the pipe. The original element material looked like horsehair which disintegrated during pressure washing.
JGC
Maark
04-25-2005 16:19:55
Usually smoke coming out of the clutch pulley is blow-by from the engine.
buickanddeere
04-25-2005 04:49:27
Lets see, disipating 38HP/28KW as heat between the pressure plate and friction disks. That's only about 60-70lbs of metal to heat up with maybe three square feet of heat disipation area. She must have had the clutch fiber disks glowing red hot.
