4430 Quad
Wi-Red
02-21-2004 19:41:18
Just purchased a 4430 that works great on low side , but when shifed to high it slips. Works better when cold. Also when in park and neutral, running for a while loose most hyd. 3pt steering and brakes. Anybody have any idea what might be wrong? Quad clutch pack maybe? Bought tractor right (I hope) at auction. Thanks for any help, Tim
Steve
02-22-2004 15:20:18
 Re: 4430 Quad in reply to Wi-Red, 02-21-2004 19:41:18
I still say supply pump bad because of loosing hydraulics,that being said something internal went through the pump and destoyed it you need to figure out what.When you get it apart be sure and flush ALLLL metal shaving out of case.There are thre drain plugs and you need to flush out GOOD.An aftermarket screen mesh that is magnetic is availiable that will also help filter out fm.Just mt 2cents Steve
DON
02-22-2004 15:09:30
ON THE SIDE OF THE TWO SPEED THERE IS A U SHAPED PIPE THAT HAS A CLAMP THAT HOLDS IT IN PLACE THEY WOULD BREAK LETTING IT COME PART WAY OUT.WHILE THE OIL IS COLD IT WOULD WORK. GET SOME GAUGES AND TEST THE PRESSURE ON THE SYSTEM AND HIGH AND LOW SIDE. WILL HAVE TO SPLIT THE TRACTOR AND REMOVE THE TWO SPEED TO FIX. A NEW UNIT WILL SET YOU BACK SOME $2000.00 SO BEWARE. DON
steve
02-22-2004 06:11:40
I would suspect the supply pump in the rear of the transmission,if your planettary 2 spd is bad spend the 2200$ and get one new from deere beeen throught got lots of t shirts and will never have another quad range.Be very critical of the supply pump and drive shaft.Ilove our 4430 all except the quad range Steve
Brokenwrench
02-22-2004 05:21:54
You have an internal hydraulic leak that is bleeding off the charge oil.It could be in the hi-lo cluch pack,but is more than likely one of the internal feed lines because you lose hydraulic function at idle. You lose hi-lo because it is fed by charge pressure. If you have access to a manual and guages,go through the pressure checks for the hyd. system to try to isolate the source before you split the tractor.You might get lucky and just have a cut o-ring,or leaky tube behind the valve body on the side of the trans.
twopop
02-21-2004 20:22:51
you most likely have a leak in the high side plumbing.there is a pipe inside the tractor that can start leaking,or any of several o-rings.your probably going to have to split it and pull the front pack.if your to do it yourself,you will need a manual
mfrancis
02-21-2004 20:18:06
Have you changed trans filter, checked sump screen, this is where you need to start. let us know if we have go into bigger things.
