1020 or 1520?
Roy in IL
04-24-2005 09:34:54
I recently bought what I thought was a 1020. The tractor has a new paint job on it with new 1020 decals. When I purchased it, they gave me the operators manual with it and it was for a 1520. I ran the serial #'s the best that I could and still not sure which it is. The local JD dealer did not do me any good either. The numbers are T4RMC 077239T. The engine numbers are M4MTR 118718T. Any info would be appreciated. Thanks Roy in IL
JYD
04-24-2005 17:49:23
 Re: 1020 or 1520? in reply to Roy in IL, 04-24-2005 09:34:54
Roy,
Here is the engine info:
M - Engine 4 - Indicates a 3-cylinder
M? - Should be a 1 (gasoline) or 3 (diesel)
T - Using factory (T is Dubuque)
R - Application (R is RU Model)
Again the next six digits are the serial number, and the final T indicates the engine was manufactured in Dubuque.
JYD
JYD
04-24-2005 17:38:20
Roy,
Here is the breakdown of the first five characters in your serial #:
T - Tractor
4 - Designates series (the 4 indicates it is a 1020)
R - Designates tractor style (the "R" is an RU)
M? - This should be either a 1 (gasoline) or 3 (diesel)
C - Designates type pf transmission (C is collar shift)
The next six digits are the serial number, and the final T indicates the tractor was manufactured in Dubuque.
Hope this helps.
Regards,
JYD
I Bleed Green
04-25-2005 15:07:53
 Re: 1020 or 1520? in reply to JYD, 04-24-2005 17:38:20
Funny you say 4 indicates its a 1020, when in my 1520 parts book it shows 4 indicates its a 1520
JYD
04-25-2005 17:44:52
 Re: 1020 or 1520? in reply to I Bleed Green, 04-25-2005 15:07:53
Yes, my 1020 PC and SM both indicate that a "4" is a 1020. Also, J.R. Hobbs in the February 2002 issue of Green Magazine says the "4" is a 1020. The serial # on my 1020 starts out with "T4R1C..." and my tractor is an original 1020 RU, gasoline, with collar shift (and a Two-
Cylinder Research Document confirmed all of this). I do not have an answer for you, definitely a mystery.
JYD
I Bleed Green
04-25-2005 17:59:10
 Re: 1020 or 1520? in reply to JYD, 04-25-2005 17:44:52
I dont have time right now, but i can scan my 1520 parts book and show you what im talking about.
pasbon
04-25-2005 12:07:01
what does the 3rd character denote if it is an H?
JYD
04-25-2005 14:46:42
 Re: 1020 or 1520? in reply to pasbon, 04-25-2005 12:07:01
The "H" would indicate the tractor is a 1020HU (will have taller rear tires, i.e. 36" or possibly even 42"). The 1020 was available as a 1020LU, 1020RU, and 1020HU. So, that third character will be L, R, or H.
I Bleed Green
04-24-2005 14:07:07
If the second number of the tractor serial number is 4 it's a 1520. Yes the 1520 has a 3 cylinder engine. If the second number of the engine serial number is 164 it's a 1520.
HTR
04-24-2005 12:00:46
If you can find the casting number on the block, you should be able to tell which tractor it is. The 1520 used the larger 164 cid engine. The block casting no. will be different for the two tractors. You could then check the numbers on the online parts book.
Mike M
04-24-2005 10:05:47
Do you have a 3 cyl. or 4 cyl. engine ? I think a 1020 is 3 and a 1520 is 4.
Roy in IL
04-24-2005 10:15:50
 Re: 1020 or 1520? in reply to Mike M, 04-24-2005 10:05:47
It has a three cylinder engine as I believe they both do. I think they went to the four cylinder on the 2020 model. I went to weir deere website and ran the numbers and the 4 in t4rmc means it is a 1020 or 1520, but does not specify. So they should both be three cylinders.
