420 Battery Door
JDCRAWLERDOG
04-23-2005 19:10:34
Does anyone know if the battery door on 40,420,430 Dubuque crawlers should have a wing nut type thumb turn latch in stead of the slotted screwdriver type latch, or did JD go to the slotted type for both crawlers and tractors at some time? Can anybody recommend a battery door replacement supplier? Thanks.
Maark
04-24-2005 13:37:27
 Re: 420 Battery Door in reply to JDCRAWLERDOG, 04-23-2005 19:10:34
When I checked last year, that wing nut was available from Deere for $52.00. I got a wingnut from the aircleaner on a combine for .75cents. Drilled a hole to put a roll pin in it, works great.
bent
04-24-2005 09:38:37
Try Lavoy Wilcox at JDCRAWLERS.COM
bent
Ray
04-24-2005 09:26:28
They came with the wing nut,but when replaced they usually installed a hood bolt because the wing nut was $15 and the hood bolt type was $7.00.
Hayfarmer
04-24-2005 09:21:14
My 430 has the slotted screw type fastener on the battery door. That is the way it came from factory but it is a late model 430. My Uncle had it since new and I don't think the battery cover stayed on it after the first battery problem and it didn't have one until I got it. Perhaps the wing nut type would have made it come off easier. On the other hand this is a 430 U and the clutch pedal works pretty close to the door so that might make a difference.
Henry J
04-24-2005 05:48:04
Crawler
I loked in my 420/430 parts book. It depicts the door as being the same for 420 series and it changing at 140000.
The picture for the 420 depicts a butterfly type thumb screw. I ordered an aftermarket one and that is what I got.
When I got mine from John Shepard, he still had NOS if you wanted it. 715-265-4988
JDcrawlerdog
04-24-2005 06:17:00
 Re: 420 Battery Door in reply to Henry J, 04-24-2005 05:48:04
Henry J
Thanks for the info. I will give John a call.
