4030 Remotes
wolfmantractor
04-23-2005 18:54:36
Have a 4030 with dual remotes - It takes about a half hour & a complete change of clothes to attach hoses. It also doesn't want to give up the hoses once they're attached. Pressure relief valve problem or ???
cannonball
04-24-2005 07:38:09
 Re: 4030 Remotes in reply to wolfmantractor, 04-23-2005 18:54:36
are these not the same valves on a 4230 i hook them up all the time with pressure on them..just asking...never been around a 4030 just a 4040...have nice day may god bless
Tx Jim
04-24-2005 05:14:12
Wolfmantractor,those series JD tractors didn't have provision's for coupling hoses under pressure.Before unhooking hoses I always kill engine and relieve pressure on hoses,then unplug.When attaching hoses you could flip up the stop in slot for scv lever,move lever forward to put scv in float position.This should relieve pressure and make plug-in easier.Tx Jim
wolfmantractor
05-06-2005 17:56:52
 Re: 4030 Remotes in reply to Tx Jim, 04-24-2005 05:14:12
Thanks Tx Jim. Good info. Pennsylvania plowboy appreciates the advice.
ET
04-24-2005 04:07:04
It sounds like there is presure on the outlet all the time. You probably need to have the valve rebuilt and ajusted. Take the valve to your dealer he has the stuff to reseat thr valves and ajust them.
