60 model
RustyAL
04-23-2005 18:25:18
Recently got a 50 and just brought home a 60. But the 60 has no identifying features or markings that it can be identifyed by. As far as I know. Can someone tell me how to be sure this is a 60. This tractor has power steering that the 50 hasn't. Could you get power steering on any JD or just some models. Ya'll are very helpful! Thanks
Mike M
04-24-2005 10:14:53
 Re: 60 model in reply to RustyAL, 04-23-2005 18:25:18
What are your casting numbers on the rear end and main case housings. A 50 should have a "B" prefix a 60 should have a "A" prefix and if you have a 70 the numbers start with "F"
CLW
04-23-2005 22:27:40
The early 50, 60 and 70 did not have power steering. It was offered in the later year models of each tractor. Your 60 is more than likely newer than your 50.
CLW
tractordave
04-23-2005 19:06:25
Power steering was always an option on 2-cylinder tractors, not standard equipment.
The serial tag should say JOHN DEERE MODEL 60 TRACTOR it would be on the right side near the belt pulley brake. If the tag is missing park the 50 and 60 side by side. A 60 next to a 50 would be like an A next to a B, very similar but the 60 should be noticeably bigger in size.
Dave
F-I-T
04-23-2005 21:59:26
 Re: 60 model in reply to tractordave, 04-23-2005 19:06:25
Wouldn't the belt pulley be a dead give away, too? I think the "B"/50 was the smaller was it like 9" where the "A"/60 was like the 12"?
Might be wrong on the numbers, but there;s a noticeable difference.
tractordave
04-23-2005 19:08:27
Sorry I misread the question, yes I do think you could get power steering on a 50.
Dave
buickanddeere
04-23-2005 22:49:38
 Re: 60 model in reply to tractordave, 04-23-2005 19:08:27
April 1954 or so and later for optional P.S. Even if the serial number plate is misisng. You maybe able to narrow down to a few months age using the parts book.
Richard Shaver
04-24-2005 06:57:09
 Re: 60 model in reply to buickanddeere, 04-23-2005 22:49:38
I have a 50 w/ PS on propane. The pully on the 50 is smaller. I know because I put the guard on from a 60 and it is not quite right. Oh well.
Another thing is the hydralic lines on a 60 going to the 3pt are longer than a 50.
I have a question. Does the power trol rear unit pull oil from the rear end oil? If so, do you need to use 30wt oil in the rear end so it is thin enough to work (very slow or weak 3pt).
buickanddeere
04-24-2005 10:54:45
 LP 50 Re: 60 model in reply to Richard Shaver, 04-24-2005 06:57:09
Where did you grap a LP 50? I've been looking for an intact LP 50,60 and 70. Dumb *ss I was and bought a 70LP in pieces last year. Two months later an intact running 70LP was offered for less than a thousand more. At least this one is a good reserve of parts. Came with a Hoxy Hitch, tachometer and air inake stack.
buickanddeere
04-24-2005 10:51:32
Two cylinders had total isolation of the engine,power steering, transmission, hydraulics, pto and transmission from each other. After some decades and hard use that wasn't always the case..... ..... Hydraulics should use a modern trans/hydraulic oil.
