Anti-freeze in oil; Deere 2240
Peter Bors
04-23-2005 17:20:37
My Dad recently bought a John Deere 2240 and the seller said (my uncle), "The sleeves are cracked and it leaks water when it runs". We took the motor apart in the frame, and the sleeves weren't cracked, except there was a lot of gunk in it that looked like water. The sleeves pulled out easy except for the middle one. My Dad pulled out the oil plug and first it leaked anti-freeze, then the oil. The "water" in the top of the motor was actullly anti-freeze. Strange, isn't it! Where is it leaking from, The o-rings? The head gasket? Please help me. We have a I+t manual coming soon, that might help. Thank You! Peter p.s. Email me at [email protected], please label the subject as "Deere 2240 engine".
Mike M
04-24-2005 10:23:00
 Re: Anti-freeze in oil; Deere 2240 in reply to Peter Bors, 04-23-2005 17:20:37
Wet sleeve engines are know for pitted liners if the coolant is not maintained. These pits can be very very small and make a very small hole right through the liner. Sometimes real hard to see. It's too late now but for future use pull the oil pan off first and put a pressure tester on the radiator and pump it up and watch where the antifreeze/water comes from before doing a tear down.
buickanddeere
04-23-2005 23:02:41
If the coolant wasn't changed or if cheapo coolant was used along with tap water. All kinds of corrosion and metal or mineral transfer will occur. Check the block and sleeves for pin holes cavitated through the metal. If the tractor was that poorly maintained. Pull the trans filter and pre screen. If it's full of silver looking specs and chips. May as well scrap the tractor. The engine work along with new brake disks, brake pads, pto and high/low clutches. Will cost more than what she is worth. You Uncle also lost the operator's manual so it's possible he didn't follow it's instructions. Did he ever put gear oil in the transmission? Can you see any sign of the last time the clutch had it's regular service? When the IT manual comes it it will be very useful. It makes a good prop to hold up the JD service manual so you can read it. 1-800-522-7448 for the real thing cheap.
Pete/ME
04-24-2005 03:44:47
 Re: Anti-freeze in oil; Deere 2240 in reply to buickanddeere, 04-23-2005 23:02:41
Weren't those three cyl. engines famous for being eaten by anti-freeze. I've got a 2240 and replaced what was in the rad. with JD 50/50 and added their conditioner. Also JD sells a test kit-litmus paper to check the acidity, although I couldn't figure out how it works. (Doesn't "I-T stand for "In the Toilet"?)
Peter Bors
04-24-2005 14:17:30
 Re: Anti-freeze in oil; Deere 2240 in reply to Pete/ME, 04-24-2005 03:44:47
Pete/ME, you said you have a 2240. How does the shifting go? Please help me or send a picture of the shifting diagram, if you have a digital camera or scanner. On my Dad's 2240, the diagram must of been a sticker that ripped off. Peter
Pete/ME
04-26-2005 02:59:24
 Re: Anti-freeze in oil; Deere 2240 in reply to Peter Bors, 04-24-2005 14:17:30
This is what mine looks like: Two shifters: right and left. Both are an "H" pattern.
Left Shifter:
Upper left-park (Put right shifter in first)(If you have a hand parking brake ignore above)
Lower left-"II" (selects high range)
Upper right-"I" (selects low range)
Lower left-"R" (you get one guess)
Right Shifter:
Upper left-1-5
Lower left-2-6
Upper right-4-8
Lower right-3-7
Good luck with the tractor.
Peter Bors
04-26-2005 14:03:20
 Re: Anti-freeze in oil; Deere 2240 in reply to Pete/ME, 04-26-2005 02:59:24
Thank you Pete/Me. It really helped me a lot. The diagram on the tractor was ripped off, somehow. Thank You! [email protected]
Pete/ME
04-25-2005 02:16:49
Wilco today when it stops @#&!* raining.
buickanddeere
04-24-2005 10:56:30
Any wet sleeve diesel diesel can be ruined quick with acidic coolant. Any wet clutch friction material will be ruined with regular gear lube.
Peter Bors
04-23-2005 18:04:23
This is Peter again and i forgot to ask if any one has a shifting diagram for the Deere 2240. I think it goes like this, but i am not sure...
left shifter... right shifter... 1 L H R 2 Extra L M
The tractor looks like it had a diagram sticker that ripped off (in picture) but we dont know the gears, my dad just bought it
Peter Bors
04-23-2005 18:10:30
 Re: Anti-freeze in oil; Deere 2240 in reply to Peter Bors, 04-23-2005 18:04:23
Sorry, picture didnt work, ill try it again! Peter heres the link thing... C:\Documents and Settings\Paul Bors\My Documents\My Pictures\Peters Stuff DONT TOUCH!!!\My Camera\Deere 2240\P4130008.JPG
Pete/ME
04-24-2005 03:37:20
 Re: Anti-freeze in oil; Deere 2240 in reply to Peter Bors, 04-23-2005 18:10:30
I'm not a geek, but I don't think we can get into your "C" drive to look at your files. Other guys can help you post a pic here.
Peter Bors
04-23-2005 18:14:56
Ill try again with the picture!
