G roll-o-matic
Daniel Chestnut
04-23-2005 16:40:16
Yesterday, I took the the front wheels and hubs on my G, so I could clean up the bearings and repack them with new grease. Once I got the wheels off, I noticed the left side knuckle was loose when it would be in the straight position, like for going over flat ground. When I put in the up or down position, it tightened up like it should be. Is there anything inside the knuckle housing that I can tighten up to fix this? I see in the I&T manual there is some bushings. Maybe they need replaced. Thanks in advance.
Mike M
04-24-2005 10:37:05
 Re: G roll-o-matic in reply to Daniel Chestnut, 04-23-2005 16:40:16
That's a very common problem with those the middle teeth wear of break off. I have built up several with weld and you have to grind them down with a small grinder like a dremal. You have to use super good welding rod that can't be machined. An old timer taught me to do these with Certainium (sp?)707 rod this was the best but hard to find.My rod supplier cross referanced that to something else good but not as good. P.S. if you find some 707 I might buy some as I can't find it in small quanties.
Kurt_JDB
04-23-2005 17:16:19
The middle gear teeth on your roll-o-matic spindles are probably very worn, or even broken. Very common problem. There is no adjusment. The assembly is pretty easy to pull apart if you want to check it out.
A good machine shop may be able to build up and rework the teeth.
Kurt
