Forklift on John Deere
Everett--Mi
04-23-2005 16:21:01
Got a Lift Master forklift built on a John Deere tractor (basket case). Said there was a noise in engine. Engine runs fine. Center broke out of flex plate that holds torque converter. Has a Perkins 3 cyl diesel model AD3-152. Anyone know where to get one or a dealer that would know what Iam talking about. Thanks for any help. My first Deere, always wanted one. Everett
Mike M
04-24-2005 10:42:28
 Re: Forklift on John Deere in reply to Everett--Mi, 04-23-2005 16:21:01
If it has a Perkins and is made like a backwards tractor I would suspect a Massey Ferguson ? Any JD of IH unit like that I have seen so far used a pretty much standard tractor just reversed the seat and steering wheel.The JD's were all JD and the IH's were all IH except for the fork unit that was hung on the back which is now the front.
Everett--Mi
04-24-2005 12:38:10
 Re: Forklift on John Deere in reply to Mike M, 04-24-2005 10:42:28
Mike M Got me to thinking, why do I think it is a JD. Just because the guy it came from said it was. So wadded out though 6 in snow to take a look. Me thinks you are right. Now I believe it is a Massy. Sorry to bother you all. Feel kind of dumb about now, but sure thank you for sitting me straight. Now I know where to get a flex plate. Supposed to get more snow tomorrow--will it ever stop!!! Thanks again!! have a nice day!! Everett
jdemaris
04-24-2005 06:56:22
I don't know anything about your machine, but I am curious. I used and worked on many Deere forklifts with three cylinder diesels - 380 Deere used Deere's own 152 c.i. diesel - same engine used in the 350 crawlers and 1020/300 wheel tractors. So, what Deere tractor platform are you referring to that uses a Perkins 152 instead of a Deere?
Everett--Mi
04-24-2005 07:56:03
 Re: Forklift on John Deere in reply to jdemaris, 04-24-2005 06:56:22
joemaris Sure wish I knew! Was looking for numbers when I scraped the paint off the intake manifold and there was the tag that said---Perkins diesel AD3-152. I thought it was a JD engine also but the parts fax for rear seal didn`t look right. Don`t know where to look for any other numbers. Could you point me in the right direction? Thanks in advance. Everett
jdemaris
04-24-2005 14:05:02
 Re: Forklift on John Deere in reply to Everett--Mi, 04-24-2005 07:56:03
Deere 152 has a Roosamaster/Stanadyne injection pump, pencil fuel injectors - seems the Perkins 152 uses a CAV pump and large-body injectors.
Everett--Mi
04-24-2005 15:59:55
 Re: Forklift on John Deere in reply to jdemaris, 04-24-2005 14:05:02
joemaris; You are exactly right, I took smeones word for what it was. Went out and checked, it is indeed a Massy Fergy. Was thinking of putting a snow blower on the forks for winter use. Thanks for helping me out. Have a nice day! Everett
