4230 hydraulic light
Gorilla
04-23-2005 15:36:59
I was using the loader on my 4230 today and the hydraulic light started flashing. What the heck does that mean? I checked the fluid & it is full and the fluid looks good. I didnt notice any difference in the operation of the tractor or loader. What should I look for? Thanks.
txgrn
04-24-2005 08:06:47
 Re: 4230 hydraulic light in reply to Gorilla, 04-23-2005 15:36:59
Before you commit harey carey, just overfill your reservoir by about 1/2 inch or so. My experience with mother deere is that the notch on the dipstice on at least 3 of her models is about 1/2 " too far down.
Additionally, the local guy who restores a lotta Deeres for a ton of bucks, mentioned it to me too (when I got my 4230 from him....and I have since proven him right).
Way to tell that's it is to check it level with the tractor running but stopped, then pull over to a hill side and tilt the tractor. If your light comes on, you don't have enough fluid in the sump. Blinking on and off tells me that you are sloshing it around and the sensor in going in and out of the fluid. Mine has done it and adding a 2 gallon jug of fluid keeps it out. My tractor is not leaking, but in using implements, it gets used up.
Mark
Gorilla
04-24-2005 15:30:55
 Re: 4230 hydraulic light in reply to txgrn, 04-24-2005 08:06:47
That makes some sense. I was using the loader to clean out a water crossing & the front end of the tractor was down. The light kept flashing though even after I brought it back to level ground & let it sit. I will change the filter just to be sure & if that doesnt do it I will put in a little more fluid. THanks.
txgrn
04-25-2005 07:17:05
 Re: 4230 hydraulic light in reply to Gorilla, 04-24-2005 15:30:55
Well, when you were straight and level, where was the fluid level on the dip stick?
Mark
gorilla
04-25-2005 10:00:19
 Re: 4230 hydraulic light in reply to txgrn, 04-25-2005 07:17:05
When I was straight and level it was in the middle of the safe range.
txgrn
04-25-2005 17:20:45
 Re: 4230 hydraulic light in reply to gorilla, 04-25-2005 10:00:19
I checked mine today since we were talking about it. I assume you have the dipstick and fill tube at the rear of the tractor near the left set of remotes.
My fluid level is about 1" above the only mark on the stick which I assume if full. Have no problems at this level.
Had a 4020 with a similar problem. Had a loader on it and if you ran the fluid at the mark or lower, it would take forever for the pump to prime, quit rattling, and get to pumpin. Keeping it a half inch or so above solved the problem and had no seal leaks on rear axles or pto shafts or anything else and the fluid did not have bubbles it it. Hence it was not overfilled as far as I was concerned.
Later,
Mark
Gorilla
04-25-2005 20:32:46
 Re: 4230 hydraulic light in reply to txgrn, 04-25-2005 17:20:45
My dipstick is at the rear by the remotes. It is a regular dipstick that has the add mark and a safe mark. I plan to change the filter tomorrow & maybe add some oil so we'll see. Where bouts in Texas are you? I live near Dallas but my place is near Hillsboro. Thanks for the help.
txgrn
04-26-2005 05:25:54
 Re: 4230 hydraulic light in reply to Gorilla, 04-25-2005 20:32:46
Up US 75 and NE toward Bonham bout half way. (Frognot)
Mark
Gorilla
04-26-2005 18:40:55
 Re: 4230 hydraulic light in reply to txgrn, 04-26-2005 05:25:54
Well, I bought a filter today and went to change it... and low and behold the wire to the sending unit had come loose at the connector. I hooked it back up and that fixed the problem. Im proud thats all it was. Thanks for the help. Most of my kinfolks are from the north texas area....celina, pilot point, denison & all over so I know bout where your at. Land got so high I had to go south to get any acreage. Take care and thanks again.
Bob
04-23-2005 16:30:33
Start by changing the hydraulic filter, noting if there's metal filings, or brake lining debris in it.
Besides a clogged filter, it could be a bad sender, or a short in the wire to the sender.
Beyond that, it gets NASTY.
High pressure leak to sump, bad quad range planetary or Perma-Clutch (if so equipped), bad transmission pump, etc.
Gorilla
04-26-2005 18:42:08
 Re: 4230 hydraulic light in reply to Bob, 04-23-2005 16:30:33
Yep, it was sure enough the wire. Thanks.
