2010 Brakes
Hendrik Alberts
04-23-2005 10:54:13
I have a 1963 JD 2010 and need to service the brakes. Does annyone know if this model has one or two diska per drum? Is it pretty straightforward to replace these diskd and where cab I get a good price on new ones?
Thganks
msb
04-23-2005 21:57:36
 Re: 2010 Brakes in reply to Hendrik Alberts, 04-23-2005 10:54:13
JDEMaris is correct on the 2010 brakes.One thing that will help for a while is to wire wheel all the ramps and balls and then liberally coat all working parts (not the pads)with Neverseize.
jdemaris
04-23-2005 15:05:43
There are no drums - they use disks and plates with actuating balls. Kind of like what Case used, but the Case brakes worked. My memory may be a little off, but I worked as a Deere mechanic for a long time up until 1991. 2010 wheel tractors never had brakes - not even when new. We tried all sorts of things to improve them, mostly to no avail. They hardly ever worked well enough to wear out, just got glazed. God help the poor guy that came down a hill with a loaded wagon hitched to the back. Now, that all being said, I recall Deere making a few attempts with updates to improve braking - but my memory is a little foggy on the matter. So, later models might have gotten some extra parts.
Wayne in Pa
04-23-2005 15:04:00
The 2010 has 2 disks per axel.
When you order disks you will probably need the series (sush as hi-crop, utility or rowcrop) they may be different.
Hope this helps.
Wayne
Hendrik Alberts
04-23-2005 19:10:18
 Re: 2010 Brakes in reply to Wayne in Pa, 04-23-2005 15:04:00
Thanks
