I did that too and still had problems. So here is what worked for me. 1. Insure timing is set correctly. As I recall they require 25 deg BTDC (static). If you are less than that she doesn't wanna go. 2. To start: Open the vaporizer valve. Set the throttle to full. Pull the choke completely out. Crank. when she lights off, immediately push in the choke, then immediately reduce the throttle to something like 1000. Wait a couple of minutes then go about your business. 3. Very important. If you are using it, want to stop it, and want to restart it within any reasonable time, do this: Shut off the vaporizer. When the engine starts to die, hit the kill switch (ign key). Restarting is as with a cold engine #2. 4. Make sure you have a large battery or a pair of batteries with 00 cables with clean contacts including those at the starter. I spent a lot of time solving the above problems and not until I did as mentioned did it start reliably every time with little effort.
