JD 40 touch-o-matic
dumb in NY
04-23-2005 06:33:02
Hi, I just got a 1955 JD 40 which runs well but has a bad leak out of the touch-o-matic selector lever. Has anyone had experience with this problem, and how is it fixed?
I also have an old case that calls for Type "A" transmission fluid in the hydrolic system. Is there an equivalent fluid I can use since it seems hard to find Type "A" fluid. thanks.
krk
04-24-2005 19:18:24
 Re: JD 40 touch-o-matic in reply to dumb in NY, 04-23-2005 06:33:02
Is your leak out of the control levers(levers on right side of seat that raise and lower the 3 pt) or the selector lever (left side under seat that allows for single or dual 3pt)? If the leak is out of the control levers then if you pull it apart you will need to use a stiff wire to fish the cam up and back into place to align the splines of the cam to the left conrol shaft (Tough but practical timesaver). If your leak is out of the selector levers then make darn sure that the 3 pt has rested at the lowest point possible or oil is gonna fly everywhere as they are under pressure. Hint - Drain the touch-a-matic of oil before you start cause it wont stop until its out anyway.
dumb in NY
04-25-2005 15:01:22
 Re: JD 40 touch-o-matic in reply to krk, 04-24-2005 19:18:24
It is the selector lever. I ordered a parts manual. thanks for the help.
Wayne in TN.
04-23-2005 15:12:19
Its a big job to stop that leak. The unit has to be dissasembled and the front housing removed to replace the seals on the control rods. Do not pull the shaft out from the outside or the cam will fall off inside the housing.
Deere reccomended using only 10w or 30w Non-Detergent motor oil in those lifts. I would not put AT fluid in them. The manual says use the same oil as in the engine.
If you tackle the job, I would get the service and parts manuals.
