49 AR hyd. won't work
Bobmn
04-22-2005 22:21:46
Hello; I hooked up a plow to my AR today, and I could not get it to lift, or lower. Ck'd the oil,it is full, and clean, I can feel the lever going "IN" and out. Using a JD ram also. Any ideas where to start? Thanks up frt. Bob
CMB
04-23-2005 05:19:03
 Re: 49 AR hyd. won't work in reply to Bobmn, 04-22-2005 22:21:46
A styled "AR" would have a "live" hyd pump located at the left rear corner of the governor housing(like a "60"). There is a shifting lever to disengage the hyd pump. This might be shut off, leaving you without hydraulics. Don't engage with the engine running, but at rest or maybe by holding pressure on the lever while "jogging" the starter.
MSM
04-23-2005 04:06:21
Do you have the pto engaged?It has to run to drive the pump.
